The installer of the IVI driver for the TDS 210 Scope fails with Internal Error 2705.Directory
We are using LabWindows/CVI 5.5 with patch 1 and with VISA 2.5.2 on Windows 2000. When we try to install the downloaded IVI driver for the Tektronix TDS 210 Scope we get the message "Internal Error 2705.Directory"
(3,808 Views)
I tried the installer and got the same error. What I did is used the LabVIEW installer. Usually LabVIEW Instrument drivers use the same CVI code compiled in a dll. The labVIEW installer creates a directory under VXIpnp called tktds2x0, which contains the C source files of the instrument driver.
Hope this helps.
DiegoF.
(3,808 Views)
Thanks for reporting the issue with the CVI installer. Please retry the installer -- all should be fine now. For future problems with instrument drivers, email instrument.driver@ni.com.
Katie
(3,808 Views)
Thanks for the quick response. We don't have LabVIEW, but I manually created the directory under VXIpnp. The installer makes it a step further before the next error message appears: "Setup has detected a traditional, legacy IVI, or third party version of this driver installed on your system. Please uninstall the existing driver before proceeding with this installation."
(3,808 Views)
thanks for the quick response
(3,808 Views)
