The path name is invalid using IVIDCPwr initialize
I want to control Rigol 832 Power Supply using standards IVI drivers
At first step, I only want to run the example included with LabVIEW "IviDCPwr [MSR] - Output DC Volts.vi"
I have download the instrument IVI driver from Rigol website: https://www.rigolna.com/products/dc-power-supplies/dp800/
I have set up it in the MAX as it is shown at the attached document.
The error appears at the initialitation of the instrument, returning:
"Error -1074135029 occurred at IviDCPwr Initialize With Options.vi"
Possible reason(s):
Primary Error: (Hex 0xBFFA000B) The path name is invalid.
Complete call chain:
IviDCPwr Initialize.vi
Where is the error?
Thanks!
Message 1 of 1
(3,048 Views)
