The procedure entry point REGISTERGPIBGLOBALSFORTHREAD could not be located in the dynamic link library GPIB-32.dll
Hello I have a NI GPIB card (AT-GPIB/TNT (Plug and Play)) or 183663c01 it is an ISA version.  I am using the visual basic files Vbib-32 and Niglobal.  I am on Windows 2000 and have downloaded the latest drivers for it I am using a PowerBasic compiler and thus have ported these files to PowerBasic Windows 8.
I think that I have successfully done so, as the languages are very simliar, however, when I run my program I get the error below:
The procedure entry point REGISTERGPIBGLOBALSFORTHREAD could not be located in the dynamic link library GPIB-32.dll.
I read on here that this function allows Basic users to use the standard  global variables: ibsta, iberr, ibcnt. Does anyone have any idea why it cannot be found in GPIB-32.dll, Is there another file I need to include or something to that effect.  The function appears to be in working order in Vbib-32 so I am stumped... (This is my first time using GPIB stuff as well as converting a VB file to PB.. so it coulde be something minor.)
Thank you
Jon
(3,572 Views)
The solution is to use the ALIAS keyword in PowerBasic.  The problem is that PowerBasic is not case sensitive, and t is trying to use a function thats name is case specific.  The ALIAS tells the compiler to look for the case sensitive name in the quotes.
Thanks Jon
(3,525 Views)
