The vi is identifyng the number of bytes to be read but the VISA Read vi is not able to read the data from the port.
Interesting; that should be a valid baud rate, and provided that it is the same for both sides, you should not see a framing error. Do you have another instrument you could try, just to see if perhaps the issue is on the instrument side?
Best,
JLS
Sixclear
Message 11 of 12
(1,381 Views)
Hi JLS,
I tried using with another MT balance. It is working fine with it. I tried the same thing with this older balance.But it did not communicate. I think there is some problem with the instrument.
Thanks for the suggestion!
Have a nice day!
Vivek
Message 12 of 12
(1,017 Views)
