Thorn EMI Electronic Loads GPIB Interface
I am able to communicate with the Thorn EMI load through the interface. It responds to Commands like "?" but I cannot set any parameters like resistance or current through the interface. Is there any info available out there?
(3,411 Views)
DESmith2000,
Thanks for contacting National Instruments.
I am glad to hear that you were able to configure your card and do some basic communication to the instrument. However, each instrument has its own specific set of commands that it will accept. The best place to find these commands is usually in the instrument's manual. If they are not in there, or you do not have access to the manual, I would suggest contacting the manufacturer for a list of commands it will accept. We do not have a command list for that instrument.
Sincerely,
Ross C
(3,411 Views)
