Threads and invalid control ID?
I have written my first program using multi-threads. Everything was working well up until last evening. I started getting invalid control ID error messages on lines of code which write to a text box that have been working for weeks. An example is below:
                SetCtrlAttribute (tabPanelEngrg, TAB_ENG_MSG, ATTR_CTRL_VAL, bfr);
Because this SetCtrlAttribute works OK some places, I suspect that I have violated some sharing between threads. The area of most changes in the past 24 Hrs has been in standard serial port code. Would this be a common symptom of thread violation? It seems that TAB_ENG_MSG shouldn't become invalid because it is a compiled in constant. Possible the tab panel handle is being corrupted.
Any comment or help on this?
I have read the two tutorials on threads. Are there any quick "rules of thumb" for writing threads.
Tahnks,
Doug Wendelboe
Solyndra Inc.
Fremont, CA
(3,253 Views)
Hi Doug,
Are you using
 int GetPanelHandleFromTabPage (int panelHandle, int controlID, int index, int *tabPanelHandle);
to get access to the handle for that particular Tab page, as in this KnowledgeBase Article:
Access a Control Located on Inactive Tab in CVI
http://digital.ni.com/public.nsf/allkb/926C2110737BEC9886257410005B5E30?OpenDocument
Can you tell me a little bit about how your program is architected so I can have a better idea of what is going on here.
Also, are you able to narrow down your program into something smaller that exhibits this problem?  If so I could take a look at it and see if I find anything that could be causing problems.
Kristen
(3,217 Views)
