Timing measurement of a Digital Output and Digital input using flat Sequence structure
Hi Guys,
i am looking to do a very basic task in labview but i am running into difficulty. i will try to explain as accurately as possible.
I want to create a Digital output  which my transmitting circuit is connected to P0.0 in frame 1 that will start a timer when the signal in frame two is received Digital input it calculates a time difference between sent signal and received signal. I have added a while loop that while the condition is not true it continues to check until it is. My vi is below but I cannot get it to work. Please help.
here is the vi hopefully someone can help
(5,347 Views)
How accurate of measurements do you need?  You will not get anything really accurate using a Windows clock.  You may need to set up a counter along with some external circuitry to get what you want.
(5,341 Views)
Hi.
My circuits consist of the following.
Tx: LM555 generating a 40kHz which is connected to an AND gate which i was using to start the sequence.
Rx: circuit is connected to an LM567 which hen the PLL detects 40kHz drops the output voltage of pin 8 to 0v.
It is this time between the intial Tx sending and the recieving of the 40kHz pulse Rx that i need to capture.
(5,329 Views)
also my NI device is a usb 6216
(5,328 Views)
I had a quick look over your code and noticed a few things that you need to implement:
  • Swap the 'Subtract' inputs to find the difference in time between the two.
  • Add a piece of code between the data output which sends a false to the 'Equal to' when the current data out equals false.
I hope this helps!
(5,309 Views)
still having trouble in getting any timing measurement at all from circuits. attached is the latest Vi
(5,289 Views)
