To implement hokuyo 30LX into PXI real-time
Hello, all
I'm trying to use hokuyo 30LX in PXI Real-time.
As you all know, Hokuyo generates the data through the USB port.
So, it works fine, if I use my laptop to use laser scanner with instrument driver that NI provide.
However, it doesn't seem working if I import the project to RT PXI for connecting laser scanner through VISA even though I tried to change the connecting environmental option from standard to crio-USB.
I saw lots of people used hokuyo with crio, but have anyone encountered similar problem with PXI operating system?
Message 1 of 1
(2,922 Views)
