To read & save data from serial port (write to .csv file), and plot data as wave
I've been stuck with this problem for weeks and really need some help. I've been searching a lot but I can't find a proper solution.
I am trying to use Labview to plot and display some parameters of a data acquisition system for a project.
The data acquisition system is connected to a computer via serial connection through COM 1 port.
The data acquisition system sends a serial stream of data (ASCII string with baud rate 19200), as shown below (from HyperTerminal),
01:00:26,933.24,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,
01:00:27,931.54,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,
The serial data stream consists of a time stamp (as 1st data), followed by 16 individual channel data, separated by comma "," and each stream ending in return "\n". Each value of the data ranges from 1 to 6 digits (value of -5000 to 15000).
 I have no problem reading this values correctly using HyperTerminal, but I have problem to plot and display individual parameters of this serial string in Labview. I want to save the entire data in  a “.csv” file corresponding to all the 16 channels with time stamp and plot each individual channel parameter in a graph with time on X-axis.
I am relatively new to Labview hope I can learn a lot from your help.
 Thank you
(3,594 Views)
Why are you reposting the same question that you posted yesterday and which was answered.
duplicate post from yesterday
(3,591 Views)
