Too many GPIB listeners
     When I Measurement & Automation Exploer to scan GPIB-USB-HS, It indicates that there are too many gpib listeners, and what should I do?
    PS:
It is ok when I reseat the GPIB
(2,580 Views)
Based on your "ps", it sounds like your issue is fixed.  Sounds like it was a loose connection on the bus.
Are you still having an issue?  How many devices are you connecting to?
(2,552 Views)
  1. Maybe it was a loose connection on the bus, it has appeared two times. There is Only one device(Agilent 66319B)
  2. if loose the connection on the bus,the NI-Max should prompt disconnection not too many GPIB listeners?
(2,507 Views)
@Vinson12138 wrote:
  1. if loose the connection on the bus,the NI-Max should prompt disconnection not too many GPIB listeners?
Not if the GPIB connection was loose.  That could introduce noise making it look like multiple devices were trying to respond.
(2,488 Views)
