Transfering measurement data from 4155 to labview
I'm running into some problems with transferring measurements from a HP4155 to labview. I've tried finding the correct commands in the programmers manual but havent found a definitive answer besides the general commands for reading the data on the 4155 itself. Do you just send a write command to the device then a read command to read the data in? I'm having trouble finding examples of how to do this correctly.
Any help would be greatly appreciated,
Konrad
(3,706 Views)
Why write your own driver
look at this page
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/nl/pg/1/sn/ssnav:idr/q/4155/
greetings from the Netherlands
(3,660 Views)
