Trouble communicating with HP8560E spectrum analyzer using C++ code excuting from DOS window.
I am often unable to control the 8560E using GPIB and C++ code from a DOS window. The executable runs from a DOS window (in Windows 98). I have used this setup with other instruments and it works fine. With the 8560E, it will not work unless I use the following procedure:
1) start my program (in a DOS window) and leave it idling
2) start NI-488.2 Communicator for my PCI-GPIB card and leaving it running.
3) run tests using my program
Is there some sort of initialization that takes place when I start NI-488.2 Communicator? If so, how can I get this "initialization" into my C++ code so that it will work without starting Communicator?
Is there some sort of special reset comma
nd that I need to use with the 8560E? Are there other special requirements or tricks for communicating with this analyzer?
(3,720 Views)
Hey Jab,
You might want to open up IBIC or some of our C examples to see if they have the same problem. You might be skipping a small step. In addition, IBIC will allow you to reproduce the Communicator in a step by step fashion.
I hope this helps out.
JoshuaP
(3,720 Views)
After browsing the manuals some more, I decided to try the EnableRemote function in my code. This seems to have solved the problem. Apparently this instrument is different from others I have programmed in that it needs this function call so that it will pay attention to GPIB commands.
Jeff
(3,720 Views)
