Trouble to communication between Labview and a RS232 Monocrhomator Oriel C130.
I need to read informations from a Monochromator (Oriel Cornerstone 130).
The connection between PC and Monochromator is through a USB 2.0 cable.
My idea is use the VISA instructions to send some strings to Monochromator.
(Ex: Visa Write, Visa Read, Visa Configure Serial Port...)
However, when i try to set the VISA resource name there is no any option of porta COM available.
I´ve already uninstalled and installed the USB driver of monochromator C130 twice. I thought it was the origin of the problem, but probably it´s not.
Does Anyone knows how to resolve this?? I need to Connect LABVIEW and the equipment.
OBS: I made a test with an Arduino, and when a plugged the USB cable, immediately appeared a COM PORT available to choose.
(3,881 Views)
