Turn off outputs when computer crashes or communication loss
Hi!
I am working on a monitoring and control system for a gas turbine for educational purposes.
I need to have some sort of safety system in case of communication loss between the computer and the cDAQ-9178.
As soon as something happens to the computer connected to the daq, all outputs needs to be set to 0.
Any ideas how i can manage that?
/Gideon
(4,048 Views)
Then a cDAQ is the wrong system.  You should be using a cRIO, like a cRIO-9066.
(4,043 Views)
I have access to all the software i need to program the cDAQ 9178, can I use the same software with the cRIO 9066 or do I need something else?
Is there any difference in programming a cRIO compared to a cDAQ?
I found out that i could use the watchdog function om some of the DAQ.
Is there any drawbacks to using the cDAQ 9188XT with the watchdog instead?
(4,024 Views)
Ok, I did not know there was a cDAQ chassis that had a watchdog.  I would go this route if I were you.  There are some Watchdog functions inside of the DAQmx->Device Configuration->DAQmx Watchdog palette.  Once configured, just reset the timer whenever you do a read or something like that.
(4,014 Views)
