U2004 power sensor VISA
Using VISA Read and Write i am able to read power sensor IDN. However when trying to use READ? or READ:PW:AC? command I can obtain only 3 measurements, the 4th one generates  Error -1073807339 occurred at VISA Read in Sensor Read_1.vi    Possible reason: VISA:  (Hex 0xBFFF0015) Timeout expired before operation completed. Any help would be really appreciate it?
(3,400 Views)
post your code and we can have a look
greetings from the Netherlands
(3,387 Views)
Maybe you are not allowing enough time to take the measurement. Increase the Timeout value which is probably set to the default of 10 secs.
Regards
Ray Farmer
(3,385 Views)
