UART Communication using GUI
I want to design a GUI for a digital electronics application. I want to generate some signals as per user selection and send values on UART. Please attached screenshot, I want to design GUI as per attachment.
Please guide on the same.
(3,486 Views)
I just see a tab control with a lot of tabs.  Do you have a specific question?
(3,470 Views)
Actually I want to create case structure from the tabs, each tab is having different function. How is it possible ?
(3,457 Views)
While loop with a Case Structure.  What part are you running into issues with?
Perhaps you should post your current VI and explain where you are getting stuck.
(3,450 Views)
