USB-485/4 Ports Failed
That looked promising but for the ports that aren't working I get the error "There was an error renaming the COM port. The IOCTL call failed." and they don't change name.
Message 11 of 12
(2,099 Views)
Accepted by topic author dgesswein
I was able to change the com port numbers of the conflicting device in device manager. Two showed up as com ports, the last one was under modem. The USB-485 stayed at the same ports so that fixed the conflict and it is now working.
Message 12 of 12
(2,090 Views)
