USB-485 Serial Connector Read Error 1073807339
I want to use a USB-485 USB to Serial Connector to control a Laser Distance Measure Sensor (WayCon LAS-Z-100).
I didn't connect the Sensor yet and just want to get the USB-485 going, but I'm always getting an error 1073807339 in the read module.
I used the LabVIEW Programming sample, which is shown on the Serial Quick Reference Guide and crosschecked all the setting with the system setting of the serial device (and I also played around with all the possible settings), but so far it always puts out that error.
Im not very experienced with LabVIEW, so please go light on me 🙂
I've also added the program and a screenshot in the attachments.
Felix
(4,167 Views)
If you don't have this sensor connected, what is? Is there some instrument that is supposed to read the sensor? What instrument?
(4,141 Views)
If the sensor isnt connected, nothing is connected: I assumed the Serial Connector will give some feedback on itself.
But i tried it also with the sensor connected and it came up with exactly the same error.
(4,140 Views)
No, there is no feedback unless you have an instrument connected.
Are you sure the command you are sending is correct? You aren't appending a termination character either (i.e. carriage return or line feed). Can you attach the manual?
(4,130 Views)
OK, i've got it working (somehow).
I connected the sensor with the serial connector again and used a .vi i found on the NI developer zone (http://zone.ni.com/devzone/cda/epd/p/id/2674)
It didnt work with the program i created (after the example given in the quick serial guide) tho, which is probably due to the missing DTR in my program (if i switch that off in the other one, it doesnt work either)
Here is the data sheet from the sensor: http://www.waycon.de/fileadmin/pdf/Laser_Displacement_LAS.pdf (its not realy usefull tbh)
(4,113 Views)
