USB-485 and vb.net run time problem
I have a problem with my compiled code using the ni usb-485 single channel cable. I'm using the standard SerialPort1 component from my tool bar window (running vs.net 2005, xp system). If I compile my program and run it while the development studio is open - All works well - meaning the correct ports are found and read/write communications work (currently using com1 from the motherboard and com3 as assigned from the usb-485 installation). If I restart the computer or just close my VS.Net development  program, both ports no longer read/write when the compiled code is run and there are no errors generated.
Any ideas would be greatly appretited (I'm currently looking into using the visans driver)
(3,434 Views)
Figured it out!
Problem was not with the hardware or drivers but was related to starting my thread to read the ports. A threadstart on the form.load event did not work predictable until I added a thread.sleep statement before creating/starting  my port monitor threads. It was a visual Studio thing.
(3,418 Views)
