10-02-2007 02:20 PM
10-03-2007
08:19 AM
- last edited on
04-22-2026
09:46 AM
by
Content Cleaner
Hi Andre,
Here is the NI-845x manual for more information about programming and here is the User Guide. The USB-8451 has 8 single ended DIO lines. To write to multiple lines you will want to use the NI-845x DIO Write port.vi. This is a function that you can then add code to. The example you are using had the NI-845x DIO Write line which will only write one line.
10-04-2007 02:03 PM
10-05-2007 05:04 PM
