USB-8451 SPI script API CS tristate
Hi Everyone,
Í just recently programmed the NI USB-8451 to communicate thru SPI using API script. My problem is everytime I finish sending the SPI command, the Slave Select/Chip Select goes to tri state in Idle mode. What must I do if I want the Chip Select to stay High when in idle using SPI script commands?
Hoping for your help.
Lesly
(3,421 Views)
Dear Lesly,
please review the following KB .
Martijn S
NI Netherlands
(3,407 Views)
