USB-8451 shows up as a RS-485 COM port
A system I've been working on for about 6 months has just had a strange problem... I set up a USB-8451 device in MAX with a VISA alias, and was able to use it for the last few months without any problems.
Last week I noticed errors when the device was called in LabVIEW, so I checked its configuration in MAX. It is now identified as a RS-485 COM port, not as a USB device.
23368iFFE5C6DAF4EF0F4B
It is also identified in Windows (Vista) Device Manager as a COM port:
23370i5DDCA19996C700B7
I'm working remotely from the system at the moment, so all I've tried doing is un-installing and reinstalling the device in Device Manager. I was thinking next of getting someone on site to disconnect the card, remove it from MAX then try again.
Any others suggestions?
Martin
(4,215 Views)
Hi Martin,
Thanks for using the forums!!
I am wondering if there is an issue/corruption with the onboard firmware. One thing you can check remotely is the vendor id etc. If you go to device manager, the NI device >> right click and go to properties.. On the details tab, go to Hardware Ids. Can you list/screenshot the data from there please?
Also please check the driver is up to date ( http://joule.ni.com/nidu/cds/view/p/id/2041/lang/en )
Let us know how you get on!
Ash
Hi Martin,
Also please check the driver is up to date ( NI-845x 1.1.4 - Windows 7 64 bit/7 x86/XP/Vista x86/Vista x64 )
Ash
Ashish Naik
Automotive Business Development Manager
National Instruments UK
(4,186 Views)
Hi Martin,
I was just wondering how you were getting on with the issue.
Take care,
Ashish
Ashish Naik
(4,148 Views)
Accepted by topic author Martin.Griffiths
Are you sure you don't have a USB-485 device attached to the system in addition to the USB-8451? In order for NI-Serial to recognize a device as a a USB-485, it would have to be able to successfully load the USB-485 firmware to the device and communicate properly with it. The USB-485 and USB-8451 are very different hardware architectures, so I would find this to be very unlikely.
-Jason S.
(4,135 Views)
Hi All,
Thanks for your replies, I've been a while getting back because my guy on site has been on holiday.
It seems there was an RS-485 port in the system, and that the USB-8451 had been disconnected. Simple as that!
Thanks again.
Martin
(4,120 Views)
