USB Data
Hello All
    I have a scanning gun is USB interface, want to use Labview through WIN7 system DLL file read scanning content, do not know how to do
(2,563 Views)
Usually, these work as keyboards, so using it with a string control should be fine. Consider this: LabVIEW Barcode Scanner Processing Issue
Else, you can use a Call Library Function Node to invoke a specific DLL from the system.
(2,461 Views)
