USB-GPIB-HS
Thanks so much for your advice! I suspected this and I'm now looking for a half-height PCI to GPIB card. Some of the ones I saw appeared to be suitable only for very old PCI slots?
Any suggestions for half-height PCI to GPIB cards since my computers can support only the small cards? Thanks!
Phil
Message 11 of 12
(658 Views)
There are also smaller PCI-GPIB models.
Please select at the time of purchase.
To make the bracket smaller, select the low-profile option.
However, in that case, the GPIB connector will also be a special small one, and you will need to connect it to the normal size connector via a conversion cable.
If you select low profile on the NI Web Shop, the only OS option available will be Windows, so please contact NI before purchasing to see if it can be used with Linux.
PCI slot definition
Full size: Length 312mm or less x Width 107mm or less
Half size: Length 173mm or less x Width 107mm or less
Low profile: Length 120~168mm x Width 64mm or less
NI PCI-GPIB size
PCI-GPIB/TNT4882C: 133mm x 107mm
PCI-GPIB/TNT5004: 120mm x 64mm
PCI-GPIB/LP: 120mm x 64mm
Message 12 of 12
(644 Views)
