USB Identification (Barcode Scanner)
Hi everyone,
I'd like to use 2- Barcode scanners via USB. So how to specify if I wanna fix text box for receive only one Barcode scanner #1 and text-box#2 receive only Barcode scanner #2.
Thanks in advance.
PB.
(2,639 Views)
I believe the Barcode scanners are going to show up as USB-HID (same as a keyboard). This scenario is similar to connecting two keyboards and trying to limit the computer responding to keystrokes from each of the keyboards.
If the barcode scanner shows up as a com port then you may be able to specify which com port you want to read the characters from.
Santhosh
Soliton Technologies
(2,602 Views)
Hi Santhosh,
Thank you for your suggestion.
So, I'm a newbie with LabVIEW. How we can read USB-HID.
By the way, 2 Barcode scanner its the same brand and model.
Thank you in advance.
Pongchat B.
(2,590 Views)
