USB Serial Input into CRio 9012
This is a hardware related question regarding inputs into a CRio 9012.  I have a prebuilt system (that I'd prefer not to touch) that outputs a string of serial data through a USB port.  On the prebuilt system, the data was converted from RS232 to USB with the use of a FTDI chip.  My goal is to read this data with the CRio, but as the on-board USB port isn't I/O, all I have access to is an on-board RS232 serial port and an analog input module (NI 9209).
Are there any good ways to read this data?  The simpler the better, but I wouldn't mind buying something like a Raspberry Pi to do the conversion if necessary.
I appreciate any help.  Thanks!
(4,149 Views)
Hello mries,
I have not personally used any converters from USB to RS232 (female DB9 port), but I can link you a few resources to help you get started on developing the cRIO code itself.
https://forums.ni.com/t5/LabVIEW/crio-serial-port/td-p/1145870
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/how-do-i-read-from-a-RS-232-to-cRIO/td-p/111...
From what I understand about your requirements it looks like a USB-232 or similar cable with a gender changer (on the DB9 connector) may be a good choice.
I hope this helps somewhat!
Alex C.
ni.com/support
(4,118 Views)
