USB based devices
hello,
I am going to interface Spectrometer with Labview using VISA /USB. Kindly guide to develop the VI and data control interface.
(4,854 Views)
Which spectrometer?
There are so many possible answers to your question that I will start with a simple question myself.
greetings from the Netherlands
(4,850 Views)
If it is a VISA device, then send it SCPI commands through the VISA WRITE and read back the instrument response with VISA READ.  Always remember to use the VISA CLOSE once your task is completed.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,839 Views)
I HAVE DATA FROM SPECTROMETER IN TEXT FILE. (*.txt) . with delimiter option as ,. I have used Read from Text file and saved datas in 2 string array. Now guide to guide to plot as continous XY plot.
(4,810 Views)
Thanks Albert. Kindly guide me to develop a VI to obtain spectrum data from Spectrometer (connects to pc through USB).
Thanks once again.
(4,801 Views)
look at the ocean optics spectrometer diver. It is not optimal but at least all the source code is available.
the next link may be stretching over more lines.
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=7833BD4A31DA1274E04400144FB7D2...
(4,792 Views)
Thanks. Albert. I will contact you for further help if needed. Let me go through this vi and understand it.
(4,780 Views)
