USB data rate with LabVIEW 7.1
Is LabVIEW 7.1 capable of receiving 100kbps via USB?
Can anyone recommend some resources for a PIC programmer, like myself, completely new to USB?  I intend to transfer data from a wireless device into a PC running Labview but haven't chosen a transceiver or PIC yet, so any advice at this stage is very welcome.
(3,857 Views)
Hi
You can acquire at 100Kbps using LabVIEW 7.1. At this sample rate the acquisition is limited by the hardware, not by LabVIEW.
With regards to your second question, I would recommend using Wifi and a TCP/IP protocol in LabVIEW. I am unable to advise on the actual hardware as they are 3rd party devices.
The following link can help you get started with TCP/IP communication in labview: Basic TCP/IP Communication in LabVIEW
Hope this helps
Regards
Beejal S
NI UK & Ireland
(3,834 Views)
