USB deletion when the serial read\write is running
HI,
      i just copied the example that help me to make a serial communication. As long as it is working fine, but when ever if my USB is deleted or if i press continously reset in my controller(which used for serial communication) i.e port is deleted then i am facing error which was attched below. i am thinking to write and display to user like if any one removes USB when the VI is running continuously or is there any way to handle this error.
attached files containes 1) working VI 2) error message if USB is deletd in between the process
        Please help me in clear way because i am new to Labview and for programming terminology.
Message 1 of 1
(2,915 Views)
