04-11-2008 12:44 PM
04-11-2008 12:56 PM
04-14-2008 03:18 PM
06-02-2011 11:17 AM
I hate to bring up an old topic, but I'm experiencing a similar issue with a SATO CL412e USB printer. I have created a driver using the VISA Driver Development Wizard. I had no problems. I see the device in both Device Manager and MAX. If I first create a VISA Resource control or constant, the USB device shows up along with COM1 and LPT1. I can then write to the printer with no problems. If I save and close the vi and open it back up, the USB device is no longer in the VISA Resource List. Even after selecting Refresh from the drop down. Sometimes it just disappears from the list just after creating the VISA Resource control or constant. I can manually type the VISA Resource alias in the drop down box and communicate with the printer, but I can't expect someone to remember to type something in there if it doesn't show up in the list. I am using VISA 5.0.2. I have the VISA class set to Instr. I can change it to USB RAW and it seems to consistently show the USB printer; however, I need it to also show the COM ports as we do still have some printers that are Serial. I guess I could use the list VISA resources vi and build the list of VISA resources. Any suggestions would be great.
Rick
06-03-2011 02:55 PM
Does the device still show up in MAX when it doesn't show up in the VISA resource control?
06-03-2011 04:40 PM
Yes, it still shows up in MAX and Device Manager.
Rick
06-06-2011 12:47 PM
Hi Rick,
Would it be possible to generate a MAX Report so that I can look a little deeper into your system. Once you generate the report you can post it on our ftp: ftp://ftp.ni.com/incoming. Just reply to this thread with the name of the file so that I know to look at it.
06-14-2011 07:51 AM
My device (Ocean Optics USB2000) shows up neither in MAX nor in the VISA resource list of the Setup.vi I downloaded last week. The spectrometer does work however under another software (LoggerPro). Could it be that MAX will not see the device because another driver is already installed? I would think that it should not matter as long as I do not run the other program.
Best regards, Ole
06-16-2011 07:01 AM
I'm assuming you got your driver from Ocean Optics. Have you downloaded NI's driver for the USB2000? It's available at the link below. In the future, all 3rd party supported drivers are available for download at www.ni.com/idnet.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=8113
As a general rule MAX shows only NI devices, however, there are exceptions. Try switching out your USB cable. If that doesn't work, then let me know and we'll troubleshoot this further.
06-16-2011 09:38 AM
Hi Shawn,
I had tried unconnecting. Now I tried again. Still no success. NO, I did not get a driver directly from Ocean Optics but via Logger Pro. I have now uninstalled LoggerPro. Windows can still recognize the spectrometer. Note that it calls it 650 and not 2000. 650 is written in paint on top of the spectrometer and 2000 on a bar code on the bottom. Yes I allready downloaded the ni-drivers (I suppose it is the Initialize.vi and OceanOptics2000-4000SpectrometerSetup.vi) I attach a screen shot.
PS: I forgot if I mentioned that the spectrometer works under LoggerPro
Best regards
Ole
