USB to RS-232
my connection configure are little complicated: I use laptop Latitude E6510 (which has no serial port) set in docking station. I use USB cable connection docking station and NI USB to RS-232 (2 port) device. then use 9-pin cable connect between converter and Keithley 2702. I can operate instrument in multi-switch scan without any problem. But when I use MAX to search the instrument which always get error -9996.
My question is: Does the USB to serial convert device have to connect PC directly?
(4,606 Views)
I don't know what you mean by ' use MAX to search the instrument'. That error seems to be instrument specific.
If you can command the instrument to perform an operation, I would think the conveyer is working.
(4,603 Views)
Converter - stupid swype.
(4,601 Views)
MAX="Measurement & Automation Explorer"
I have to use the convert because my laptop does not have serial port
(4,592 Views)
Accepted by topic author luli8697
Hi
There is no problem with the serial port or converter when it works. A usb connection in the docking station is a connection in the machine itself for the software. I have also an e6510 and see no problem.
MAX will not find the k2700 becasue MAX does not scan the serial ports.
greetings from the Netherlands
(4,588 Views)
Hi I also have a similar problem
I have an USB to R232 converters and im trying to communicate with a Varian AGC-100 with attaced Manual
Im using Measurement and Aquisation explorer from NI
The problem i have is that i just get some random pressures no matter which command i send to the device
using Query or write and read
has anyone an idea what the problem could be
with kind regards Venu
(4,558 Views)
