USB usb to com adaptor
I am using a USB to serial adaptor. Trying to perform the "loopback test" I received an 1073807246 error message saying that "VISA:(Hex 0xBFFF0072)The resource is valid but the VISA cannot currently acess it. Could somebody has an idea why this is happening? NI-VISA 4.4.1 is installed.
Thank you in advance
(3,468 Views)
Hi thorfano,
Please try the steps mentioned in this help topic:
VISA Troubleshooting Wizard: Error -1073807246
This error is usually caused by opening a session which has already been opened. Hope this helps!
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,435 Views)
Good morning AI B,
Unfortunatelly, I have already tried the steps proposed but didn't help.
Best regards
(3,399 Views)
Hi thorfano,
Sorry to hear you are still having problems.   A couple other things to check:
  1.  Make sure you are not accessing the device from any other source
  2.  Close all programs, and try communicating in a VISA test panel in Measurement & Automation Explorer.  Do you still get the error here?
Al B.
CTA/CLD
(3,358 Views)
