USB625:1 incompatible on linux?
I really hope that question has never been asked before (i searched for quite a while now).
Context: I am working with a Thorlabs OCT system (Callisto) which i composed of a NI USB6251 card that control all the components inside. The Thorlabs company told me they don't have a linux compatible SDK and told me to check with the NI SDK. As of now I tried to connect via VISA and nidaqmx from my linux distribution (Scientific Linux 7 (CentOS based)) but I can't seem to find the usb device anywhere. I tried on a windows computer with NI MAX and it worked so now I really am stuck to this point.
So the question is: As I am not working on labview, is there a way to communicate with the USB6251 from my OS? If yes, is there example on how to do so?
Sorry if this sound like a dumb question, I am not really use to work on interface.
(2,561 Views)
Which driver version did you try? I found DAQmx base 15.0 on web but,
it seems that the driver doesn't provide a support for USB-6251...
(nevertheless PXI-6251 are supported...)
Looking into this forum, NI-DAQmx Base for LabVIEW 2017 on Mac OS X
the driver is the latest version.
Do you have other device can be tried?
Certified LabVIEW Developer
GCentral
(2,530 Views)
