UT8805E Pyvisa Communication
I also have a  UT8805E and this EOFError issue. It looks like the UT8805E doesn't pad the response to a multiple of 4 bytes. This is why some commands might work and others might not if the response is a multiple of 4 bytes. The underlying commands are working, pyvisa is just treating it as malformed as far as I can see. If I craft raw VXI commands it returns the data fine.
UT8805E firmware version: V1.87.014
$ pyvisa-info
Machine Details:
Platform ID: Linux-6.8.0-87-generic-x86_64-with-glibc2.39
Processor: x86_64
Python:
Implementation: CPython
Executable: .venv/bin/python3
Version: 3.12.3
Compiler: GCC 13.3.0
Architecture: ('x86', 64)
Build: Nov 6 2025 13:44:16 (#main)
Unicode: UCS4
PyVISA Version: 1.15.0
Backends:
ivi:
Version: 1.15.0 (bundled with PyVISA)
Binary library: Not found
py:
Version: 0.8.1
ASRL INSTR: Available via PySerial (3.5)
USB INSTR: Available via PyUSB (1.3.1). Backend: libusb1
USB RAW: Available via PyUSB (1.3.1). Backend: libusb1
TCPIP INSTR: Available
Resource discovery:
- VXI-11: ok
- hislip: ok
VICP INSTR: Available
TCPIP SOCKET: Available
PRLGX_TCPIP INTFC: Available
PRLGX_ASRL INTFC: Available via PySerial (3.5)
Message 11 of 18
(1,214 Views)
I logged a ticket with Uni-T support and they gave me a new firmware release that fixed this issue.
The new working firmware is V1.87.017.
It now pads the 4 byte alignment correctly and works with pyvisa, at least for my simple tests.
Message 12 of 18
(1,176 Views)
FYI - if you're not using any NI product - licensed software or hardware, you need a license to use NI-VISA, though not enforced, but legally compliant.
NI-VISA Deployment Licensing - NI
Santhosh
Soliton Technologies
Message 13 of 18
(1,171 Views)
Santosh,
I can't comment on the NI-VISA backend compatibility, it may or may not work, this was just about the pyvisa-py issue that the original poster had. Pyvisa-py enforces the XDR standards that Uni-T were not following.
https://github.com/pyvisa/pyvisa-py
Cheers
  Steve
Message 14 of 18
(1,168 Views)
Where can I find this firmware ? Only see version 014 on their website ?
Message 15 of 18
(1,140 Views)
Their engineer sent it to me via email. I guess they will release it publicly soon?
Message 16 of 18
(1,134 Views)
Oke, I’ll keep an eye on it unless you don’t mind sending it to me (jomosoft@yahoo.com) ?
Message 17 of 18
(1,127 Views)
Message 18 of 18
(1,108 Views)
