Unable to Run NI-488.2 Software
I am running an iMac with OS X 10.5.8, a 2 GHz Intel Core 2 Duo processor, and LabVIEW 7.1.  LabVIEW said it installed correctly, and I have even gone back and reinstalled the GPIB software on its own.  I've tried reinstalling the entire software package several times.  When I try to run the NI-488.2 softwares, the following things happen:
EthernetConfig: Starts to open, and then just closes itself
Explore GPIB: Unable to load libgpibconf.jnilib.  Reinstall the NI-488.2 driver software.
FirmwareUpdate: Cannot launch Java application.  Uncaught exception in main method: java.lang.UnsatisfiedLinkError: no EnetConfig in java.library.path
Troubleshoot: The NI-488.2 Software is not correctly installed on your system.  Please follow these steps: 1) Reinstall the NI-488.2 Software. 2) Run the Troubleshooting Wizard again.
Any help would be great.  Thanks.
(5,303 Views)
How does one go about 'running" NI-488.2 software ?
(5,298 Views)
I fixed it, thanks in no part to your completely useless comment
(5,286 Views)
You are welcome for your completely useless question.
(5,282 Views)
