12-04-2017 02:50 PM
Hi nitad54448,
Maybe you posted the wrong file? Maybe you don't have the same Keithley 181?
What you posted has no instrument specific commands related to the Keithley 181. At fi In the 5 message in this thread is a screen shot of the only commands that the K181 understands. None of those are anywhere in the "driver" you posted.
A driver should support a big whack of all instrument features, and the examples should work. If you open an instrument drivers VI tree, you would expect the VIs contained inside to do what they claim. Try any of the VIs in file you posted and not one of them does anything remotely relevant to the K181. They all contain IEEE 488.2 and SCPI commands for a voltmeter, but not commands for the K181 specifically. So its not a K181 driver IMHO.
12-04-2017 04:11 PM
oops, yes I might have posted a wrong file.
the original file is here
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/keithley-181/td-p/650373
(I am using for 9 years now 🙂 )
12-05-2017 04:30 AM
Hi everyone,
Last night I discovered the problem with my kei181. Once a timeout erro occurs for some reason the equipment will not accept commands any more. I checked the status byte and it's fine. Something makes the kei181 trapped in a "limbo". I had to restart the equipment (turn on and off ) and with the "X" in the end of the commands I could communicate successfully with the instrument. You see, when I was clicking "Communicate with instrument" in NI-MAX it sends the *IDN? right away and created the whole problem. Thanks cstorey.
Regarding the driver, I wasn't able to use it yet. Seems some internal VIs are missing . But looking inside the VIs have given me a pretty good notion of how to treat data and implement other functions. Thanks Nitad.
Now I think I can start controlling this kei181
This was very helpful, Thank you all.
12-05-2017 10:31 AM
Great!
Good luck with the rest of the programming. If you need help post your questions with code to a new thread.
11-06-2018 04:31 PM
I did confirm that the 181 does read instructions and
output data... It looks like this, with the uV reading buried
in a bunch of stuff...
<- NDCV+0.204843E-3«x0D»
I'm glad that it did work and that the 181 isn't the problem!
I'll watch here for more clues on how to get it fully working...
THANKS!
11-06-2018 09:05 PM
Right, the 181 has a very specific return string format. So once you read data from the 181 you need to parse the return string to get the reading into a numeric value. There are plenty of ways to do that, here's one..
You should probably add some of your own error handling in case the string you read is not formatted properly.
Hope that helps.
PS - Rather than post to old threads, start a new thread with your specific questions, a descriptions of your problem and what you've tried. To get good help, be very specific and post your code. Then keep all updates to that thread rather than spreading things out over many threads Just adding comments at the end of another thread without context doesn't help other people looking for solutions in the future.
