Unable to communicate with equipment using GPIB-USB-HS
Hello community!
I am currently using a gpib-usb-hs to communicate with my Agilent 6611C via python but when I run the code I get the following error:
"pyvisa.errors.VisaIOError: VI_ERROR_INV_SETUP (-1073807302): Unable to start operation because setup is invalid (usually due to attributes being set to an inconsistent state)."
Code used:
import visa
rm = visa.ResourceManager()
dev = rm.open_resource('GPIB0::0::INSTR')
print(dev.query("*IDN?"))
Has anyone come across a similar issue and have been able to solve it?
Thank you in advance for the attention!
(3,419 Views)
Can you communicate with the device via NI-MAX?
Is the GPIB address really 0?   ( 0 is allowed just uncommon.)
Does this instrument need a secondary address?   GPIB0::0::2::INSTR?  Some PSU are chainable and have secondary address you need to use to address them.
Should you have a termination character with that "*IDN?"  like "*IDN?\r".
I haven'r used PyVISA in a long time, and you are likely to get better answers on its use elsewhere.
(3,399 Views)
Typically your GPIB0::0 is the controller and it will not respond to a command to itself.  Do you know the address of your controller?  Can you Poll for instruments on the GPIB0 bus?  It may give you the answers or at least a direction to follow.
Additionally, older pieces of equipment or firmware will not respond to the "*IDN?\n", but will to the previous "ID?\n".
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,365 Views)
