Unable to initialize the VISA library
/usr/local/vxipnp/linux/NIvisa/NIvisaic     -->          Unable to initialize the VISA library. The VISA Interactive Control utility will exit.
Running RHEL 5.11 (32-bit)
[root@x74943 ~]# rpm -qa|grep nivisa
nivisa-4.5.1-f0
[root@x74943 ~]# rpm -qa|grep ni488
ni4882i-2.5.1-f0
gpibexplorer and driverwizard start up fine. I've never used nispy, but it is bombing too.
x74943(paul.autore)8> ./nispy
LabVIEW caught fatal signal
8.2.1 - Received SIGSEGV
Reason: address not mapped to object
Attempt to reference address: 0x10
Segmentation fault
Uninstall and re-install of NI-VISA didn't help. NIvisaic was running fine days ago. This system was not patched since it was working OK, but the root partition was reduced and a new physical volume was created for LVM so that /var, /tmp,... could be copied over and remounted as separate file systems.
I have not tried yet to mess with reinstalling NI-488.2
ldd /usr/local/vxipnp/linux/NIvisa/NIvisaic     shows same output as an identical working system
(4,606 Views)
This issue has been resolved. It may have been the re-install of NI-488 that really solved the problem. The ‘gpibprtk.ko’ module had a problem loading, but we also found a problem with a shared memory kernel parameter.
(4,577 Views)
