Unable to load libgpibconf.jnilib
Error when running GPIB Explorer on OS X 10.2 on iBook with JAVA 1.4.1
(3,317 Views)
Could you provide more details about the problem. Is libgpibconf.jnilib in the path? Is it installed at all? Does this happen when you try to start the program or at some later point? Can you provide any other information that might help?
Best Regards,
Aaron K.
Application Engineer
(3,317 Views)
libgpibconf.jnilib is not installed and the problem happens even after a restart of the system.
(3,317 Views)
