Unable to read from ENET-485/4 serial ports on Linux
We're attempting to read and write from a 4-port NI ENET-485 device on Red Hat Enterprise Linux WS 4 (connected directly via a crossover ethernet cable).  The device has been successfully configured to use the ip 192.168.0.200 and we're able to successfuly run a loopback test on Windows.  However, when we run this same loopback test on the Linux machine, the viOpen and viWrite complete successfully but the viRead comes back with a timeout error.
The address we are using is as given within visaconf:
ASRL0::192.168.0.200::x::INSTR
(where x is 1, 2, 3, or 4 corresponding to the port)
Talking to the ports directly via NIvisaic on Linux gives the same results:  VISA Open and VISA Write return success but VISA Read results in a timeout error.
We also tried using different versions of the NI-VISA driver.  Originally we were running v4.2 and tried both upgrading to v4.3 as well as downgrading to v4.1 (based on this thread... http://forums.ni.com/ni/board/message?board.id=140&message.id=26153&query.id=45715#M26153), all to no avail.
Any ideas on what we might be missing?
Thanks in advance for your help,
Melissa
(4,100 Views)
Melissa,
Are you getting any data back at all when you try to read back during the loopback test? I will keep looking into this to, but it might also be useful if you wouldn't mind posting the NIspy capture from your Linux machine.
-Marshall R
(4,085 Views)
No data is coming back at all when running the loopback test on Linux.
Attached are NISpy captures:
nispy_linux - capture from running a simple test written in LabView on Linux.
nispy_windows - capture from running that same simple LabView test on Windows.
nispy_linux_def - capture from running the example vxipnp/linux/NIvisa/Examples/C/Serial/RdWrtSrl.c on Linux.
Melissa
(4,044 Views)
Howdy mshi,
The only difference I can see between the LabVIEW Linux application and LabVIEW Windows application, from the NI Spy capture logs, is the line 9 of the nispy_linux1 log that deals with the termination character enable (TERMCHAR_EN). This shouldn't really affect the communication, though.
Since the application works in Windows, we at least know your ENET-485 is functioning. Now since we're having problems in Linux, I suspect some configuration issue. Just out of curiosity, do you have the necessary ports open in your Linux OS? This article lists the ports needed to be opened: KnowledgeBase 2GD9CL6Q: What Ports Do I Need to Open on My Firewall for National Instruments Softwar...
Warm regards,
pBerg
(3,982 Views)
Please try setting the serial wire mode attribute using viSetAttribute on VI_ATTR_ASRL_WIRE_MODE.  It may be defaulting to -1, which is an invalid value, and the loopback most likely should be set for wire mode of 0.  If 0 still gets a timeout, try the other valid values.  Please see the NI-VISA Help for more details.
Gavin Fox
Systems Software
(3,972 Views)
