01-13-2016 12:33 PM
I am trying to communicate with a Newport ESP301 controller via USB, using the NI-VISA or PyVISA library.
Here is some information about my machine:
python -m visa info
Machine Details:
Platform ID: Linux-3.16.0-53-generic-x86_64-with-debian-jessie-sid
Processor: x86_64
Python:
Implementation: CPython
Executable: /usr/local/bin/python
Version: 2.7.10
Compiler: GCC 4.8.4
Bits: 64bit
Build: Nov 24 2015 14:35:43 (#default)
Unicode: UCS2
PyVISA Version: 1.8
Backends:
ni:
Version: 1.8 (bundled with PyVISA)
#1: /usr/local/vxipnp/linux/lib64/libvisa.so:
found by: auto
bitness: 64
Vendor: National Instruments
Impl. Version: 15728640
Spec. Version: 5243904
py:
Version: 0.2
ASRL INSTR:
Please install PySerial to use this resource type.
No module named serial
TCPIP INSTR: Available
USB RAW: Available via PyUSB (1.0.0b2). Backend: libusb1
USB INSTR: Available via PyUSB (1.0.0b2). Backend: libusb1
GPIB INSTR:
Please install linux-gpib to use this resource type.
No module named gpib
TCPIP SOCKET: Available
lsusb:
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 008: ID 104d:3001 Newport Corporation Bus 003 Device 007: ID 04b3:310c IBM Corp. Wheel Mouse Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 005: ID 04f2:b217 Chicony Electronics Co., Ltd Lenovo Integrated Camera (0.3MP) Bus 001 Device 004: ID 0a5c:217f Broadcom Corp. BCM2045B (BDC-2.1) Bus 001 Device 003: ID 147e:2016 Upek Biometric Touchchip/Touchstrip Fingerprint Sensor Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Attempting to use the PyVisa library:
>>> import visa
>>> rm = visa.ResourceManager('@py')
>>> rm.list_resources()
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python2.7/site-packages/pyvisa/highlevel.py", line 1560, in list_resources
return self.visalib.list_resources(self.session, query)
File "/usr/local/lib/python2.7/site-packages/pyvisa-py/highlevel.py", line 238, in list_resources
raise errors.VisaIOError(errors.StatusCode.error_resource_not_found.value)
pyvisa.errors.VisaIOError: VI_ERROR_RSRC_NFOUND (-1073807343): Insufficient location information or the requested device or resource is not present in the system.
>>> exit()
Attempting to use the NI-VISA library:
>>> import visa >>> rm = visa.ResourceManager() /usr/local/lib/python2.7/site-packages/pyvisa/ctwrapper/functions.py:1225: VisaIOWarning: VI_WARN_CONFIG_NLOADED (1073676407): The specified configuration either does not exist or could not be loaded. VISA-specified defaults will be used. ret = library.viOpenDefaultRM(byref(session)) >>> rm.list_resources() (u'ASRL5::INSTR',) >>> exit()
Why am I unable to see the USB instrument in the resource list? Any help is appreciated. Thank you in advance.
01-14-2016 09:40 AM - edited 01-14-2016 09:50 AM
Have you ensured you configured the NI-backend correctly?
Review these processes:
https://pyvisa.readthedocs.org/en/stable/configuring.html
If you are sure this has been done correctly, consider the following:
Have you been able to communicate with this device before?
Do you have another USB device you could try using to verify the ports and wires are working properly?
Do you have a different machine you could try it on?
