Uninstall the NI 488.2
How can i Uninstall the NI 488.2....?, i did not find it on removing/unistall program in WIN7.
(6,588 Views)
When i try to remove it using the NI LabVIEW device Driver DVD August 2011, the error i found  is attached.
it says i t can not be removed, repired... why,, is there any other software should be removed first inorder to remove it or anything tricky procedure there to remove ?
(6,587 Views)
when i remove the NI VISA using Device Driver DVD... here is the ?
(6,580 Views)
Sorry.... the Previous one is not true.... ther is no change in NI 488 after unintalling NI VISA ...
(6,579 Views)
Accepted by topic author Sri.VI
ITS TOO EASY................. JUST GO TO CONTROL PANEL/ UNINSTALL A PROGRAM/ NATIONAL INSTRUMENTS PROGRAMMS/ DOUBLE CLICK AND CHOOSE NI 488 FOR REMOVE....... RESTART AND COMPETE THE UNSTALLATION............. TOO EASY
THANK YOU
(6,575 Views)
