Unknown code error in Python using NI GPIB-USB-HS
I am using NI GPIB-USB-HS device to control Keithley 2700, Chroma load and Agilent DC power supply. I have all the devices connected and I can see it as the GPIB devices in Python.
But when I tried this self identification command, I get an error saying,
This happens to any command that I try to run. I have the drivers installed. I am not sure where I am going wrong.
Is there any setup that should be done before running these commands? Any suggestions would help.
Thank you!
(2,149 Views)
Looks like you have pyVISA configured correctly, but just in case read - https://pyvisa.readthedocs.io/en/1.8/faq.html#faq
Which device is at address 3? Keithley 2700 and the Agilent DC supply (if it's newish) should reply to "*IDN?"  Not sure about the Chroma.
Are you sending termination characters or how are they being handles?  I think at the least that needs a "\r", o r"\r\n" but it depends on the instrument settings.
Its been awhile since I used pyVISA, but I think termination or timeout is the problem here.  Look here for details - https://pyvisa.readthedocs.io/en/1.8/resources.html
Craig
(2,096 Views)
