Unknown physical repeated capability selector
I am trying to run the LabView Example IVIDCPwr - Output DC Volts.vi
I am using Agilent N5746A DC Power Supply. I have configure the MAX to set the logic name and set up the driver and using VISA test Panel I can comunicate with the instrument and execute commands.
But when I try to run this labview example appears the following error when I try to set the Over Voltage limit:  "Unknown physical repeated capability selector".
I attach a screenshoot of the error.
(5,782 Views)
I am having a similar problem using LabWindows/CVI V9.1.1 (and ICP4.2, VISA 5.0.3).  See the attached for screenshots of error and code.
I am trying to communicate with an Agilent N6702A DCPS.  Basic commands like Initialize and Selftest work fine, but when I query a specific supply (the N6702A holds 4 different supplies), I get this error.
Thanks in advance!
Chris
(5,183 Views)
hi
Does anyone found solution for this? though this is old thread...I am also facing same error.
(4,533 Views)
Which instrument are you using, the 5746 or the 6702. One poster was using LabVIEW and the other CVI. What about you? Since this thread is old, you should probably start a new one with detailed information.
(4,524 Views)
