Unsupported version of National Instruments system component detected installing VISA 5.x.x
I have the same problem while installing LabVIEW 2010 on a Windows 7 32 in a Virtual Machine with an installed LabVIEW 7:
"Nicht unterstützte Version von NI-IMAQ gefunden."
Problem is: I absolutely need all versions of LabVIEW, starting at 7, especially version 7 in order to create compatible VIs for our customers. Also I need all versions to check and correct customer VIs doing  customer support. I do not want to create a VM for each existing LabVIEW version.
LabVIEW 2011 seems to install without problems. But I need LabVIEW 2010 too, because if I correct a customer VI, which is 2010 with 2011, the customer can not read the corrected VI anymore.
Is there any solution?
Thanks in advance
Stefan
Message 11 of 15
(1,652 Views)
Problem solved with extra installation.
Message 12 of 15
(1,650 Views)
Problem not solved. MAX wont show my GigE Cams.
Message 13 of 15
(1,647 Views)
The only Windows OS that supports LabVIEW 7 through LabVIEW 2011 is Windows XP.  However, even if you were comfortable using Windows XP, there is no NI-IMAQ version that supports this many versions of LabVIEW.  So, in summary, you need to create a series of virutal machines based on the OS / LabVIEW / IMAQ versions you are trying to support.
See links in Eric-M's previous post:
Eric-M wrote:
One thing I noticed about your programs is that you have LabVIEW 8.0 installed.  LabVIEW 8.0 is not officially supported in Windows 7.  Is it possible for you to remove LabVIEW 8.0 from your computer?  Also, I do not believe that Visa 5.1.1 is compatibile with LabVIEW 8.0.  You can find these compatibility charts in Windows Version Compatibility with LabVIEW and Compatibility between LabVIEW and NI Drivers.
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 14 of 15
(1,640 Views)
Oh oh.. I have 1 TB hard disc only.... I will do as suggested.
Message 15 of 15
(1,637 Views)
