Use RS232 and Yogogawa WT230 to get Wh
I use Labview to get voltage, current, power and wh from WT230 by using RS232. I can get the data of voltage, current and power, but it can not work in "wh".
I download the driver from
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1805
I select Plug and Play (project-style) and run the sample vi from the above link.
I can get the V, A and W from the sample vi but I cannot get the wh. It's no error message and return a error reading, for example 0.999xe-6.
I have used "Configure Measurement Normal.vi" and set the "Measure Item" to Wh. Also send "START" comment to WT230, for example "INTEGrate:START".
Can anyone give me a suggestion? Thank you.
(3,986 Views)
Did you try running the Time Integration Example in the driver?
In that example you should just have to change the constant from 0 to 9 on the block diagram
(3,975 Views)
Hi jjp377,
I have tried the example vi. what's meaning for 0 to 9? if I want to get wh, which constant to set in Integ Mode and Integ type?
(3,966 Views)
Sorry I had modified the example.  I don't have the manual, I think the defaults should work. Time Integration Ex
(3,952 Views)
