Using Fluke Compass with GPIB-USB-HS
I am trying to communicate with our Schwien manometer using Fluke Compass with a NI GPIB-USB-HS. I am able to talk to the manometer with NI VISA but not with our Fluke Compass software, Compass does successfully communicate with other equipment on the bus. I used NI trace to look at the Command I am sending to the manometer and noticed some differences. Visa sends the Command D as "D", but when compass sends it, there are a couple of periods after the command "D..". Attached is a screenshot of I/O Trace. Does anyone know why I am receiving an EABO?
(6,005 Views)
Since there is no problem with VISA/MAX/NI hardware or software, you are probably better off contacting Fluke.
No attachment either.
(5,996 Views)
You need to understand from Fluke what the command should be.
This has nothing to do with the GPIB-USB-HS.
(5,993 Views)
(5,985 Views)
Not sure what the screen capture is suppose to do.
We have already told you to contact Fluke.
(5,973 Views)
