Using GPIB for data aquisition
We have a home-made potentiostat which we are currently controlling with a DAQ card and LabView. We also have software for a commercial potentiostat which is controlled via GPIB. I was wondering if there is some sort of adapter that would allow us to control our home made device with GPIB and the commercial software.
(3,546 Views)
mya, While there probably isn't a simple adapter that would do the trick you do have a couple of options. If your home-made device has any PCI slots available then you could use a PCI-GPIB board. If not then you would likely have to use on of our ASICs to create a GPIB talker/listener device, possibly using NI-Device to create your driver.  Hope this helps! Craig H.
(3,515 Views)
mya,
While there probably isn't a simple adapter that would do the trick you do have a couple of options. If your home-made device has any PCI slots available then you could use a PCI-GPIB board. If not then you would likely have to use on of our ASICs to create a GPIB talker/listener device, possibly using NI-Device to create your driver. More information on these tools can be found here:
NI ASICs
Hope this helps!
Craig H.
(3,514 Views)
