Using IBIC (DOS Interactive Control) to talk to HP3457a DVM?
I am trying to determine the maximum data output speed of an existing setup;
NI   AT-GPIB/TNT   ISA card in a Pentium 500 DOS computer
HPIB cable to HP 3457a DVM
IBdiag and IB test say my card is working ok.
I can use  IBIC to get some communication with the DVM (IBRD 16 reports the current voltage)
but  if I try to send a command to the DVM such as IBWRT "BEEP"  or DISPLAY OFF , nothing happens.
I suspect I may have the EOI flag or EOS flag or ??? set wrong    (EIO last  now = 1,  EOS now = 0).
How can I send commands to the HP3457a?  and ideas appreciated!
Thanks!
(4,111 Views)
Do you have the manual for the HP3457a?
Have you taken a look at this forum?
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E95BC659CE034080020E748...
It may point you in the right direction.
(4,083 Views)
