Using Keithley 2601 as Potentiostat
Hi all, I have labview 8.5 , SCB-68 and KEITHLEY 2601. Is it possible to use the Keithley as a potentiostat to do Electrochemical experiments.
I need to have a -1 V between a cathode and the reference electrode when I am applying potential between the anode and the cathode??
Any idea will be really appreciated.
Message 1 of 8
(6,181 Views)
You need to specify voltage control and an appropriate current limit and the 2601 should be able to do that.
greetings from the Netherlands
Message 2 of 8
(6,178 Views)
Hi,  similar  situation. we have a keithley  2635 with usb-gpib interface, and a PXI 1045 with 6259 and scc- 68. We also have a kusb- 3116.
we need a potentiostat for electrochemical measurements and cyclic voltammetry, potentiometry, etc..
Message 3 of 8
(5,427 Views)
You have not asked a question. You have not described any problem you are having so what is the point of this post?
Message 4 of 8
(5,425 Views)
The question is implied. How we build a potentiostat for electrochemical analysis with this equipment. I thought that UPV had taken a step forward and could help.
Message 5 of 8
(5,414 Views)
And you did not notice that the post is 4 years old?
Message 6 of 8
(5,410 Views)
try to define what a chemist means with potentiostat.
What accuracy do you expect in sweeping and measuring.
Message 7 of 8
(5,402 Views)
Keithley has an App note about using a 2420 as a potentiostat. Anything a 2400 can do you can do with a 2600.
http://www.keithley.com/data?asset=4083
Message 8 of 8
(5,395 Views)
